AF Mobile
Page 1 of 2
1 2 >
Car Modeling>Acetone vs Lacquer thinner
denle 01:31 PM 10-28-2010
Is Acetone a good choice for airbrush cleaning? or should I only stick with lacquer thinner?
[Reply]
Lownslow 01:49 PM 10-28-2010
i use laquer, acetone works great for speeding up the dry time on tamiya
[Reply]
denle 03:46 PM 10-28-2010
ok, but isn't the acetone is less harmful and economical then lacquer thinner for airbrush cleaning?
[Reply]
Lownslow 04:46 PM 10-28-2010
no its more harmfull youll dry out the o rings on a airbrush
[Reply]
MidMazar 07:58 PM 10-28-2010
Dude stop and spend the extra money for the right thinner. A long time ago i tried using acetone to strip a paint job and guess what it melted the whole model in the matter of an hour. To the point that i couldn't even fix it, melted the plastic really bad!!
[Reply]
denle 07:58 AM 10-29-2010
in that case i might stick with lacquer thinner or some kind of airbrush cleaner.
[Reply]
Corre 09:48 AM 10-29-2010
Same here, bad choice that acetone. I had to throw away a whole RX7 body.
I use those big bottles of Revell AMG. Not too expensive (at least here in BE) and you can use it for quite a while.
[Reply]
Porsnatic 12:05 PM 10-29-2010
What's bottles of Revell AMG?
[Reply]
935k3 09:36 PM 10-29-2010
Laquer thinner sold in most hardware stores is just plain cheaper and more effective at cleaning all types of paint except the water based Acrylic paints. For the Acrylics flush the airbrush with water then run some 70% or preferrably 91% alcohol through it. Ammonia can also be used to clean the Acrylics but water should then be used to rinse the airbrush as ammonia after awhile will start to eat the metal parts of the airbrush. Using expensive thinners and reducers to just clean the airbrush is a waste of money.
[Reply]
stevenoble 07:49 AM 10-30-2010
Go to any automotive paint suppliers and buy 5 litres of cheap lacquer thinners. It's sometimes referred to as simple 'Gun wash' it will last you a very long time. I bought one 3 years ago and it's still going strong. I just have a smaller bottle that I keep filling from the larger one....
[Reply]
klutz_100 07:53 AM 10-30-2010
For cleaning up after acrylics, the best, cheapest and most easily accessible cleaner I have found is Mr Muscle (or similar) household window cleaner.
[Reply]
Macio4ever 12:40 PM 10-30-2010
I use acetone all the time for cleaning purposes. It wipes out acrylics, laquers and 2k and it is cheap as chips.
Mr Muscle is OK and less harmfull but not as quick and hot as acetone.
[Reply]
denle 04:15 PM 10-30-2010
Any problem with using acetone? will it damage the o-ring inside the airbrush?
[Reply]
Macio4ever 03:20 AM 10-31-2010
No problem with orings. I have ABs Tamiya, Iwata and Gunze and all of them have been treated with acetone without any issues.
I would not worry. Do not bath them in acetone :-) just clean them well.
[Reply]
Corre 12:49 PM 10-31-2010
these bottles. I only use them to clean my AB (all types of paint) and remove paint
[Reply]
Page 1 of 2
1 2 >
Up
