Has anyone here ever used House of Kolor "custom color" paints before?
I painted a Grand National in "black diamond" and it came out great, then I cleared it with testors "wet look" clear, buffed and waxed. Best looking finish imo.
But now its acting up, I have a Supra in the booth and I went to mix up some red metallic and it seems that the paint reacts to the thinner. It spreads apart like water and oil. I used testors thinner in my last batch and it worked great but now its hell. The paint gets real thick and bunches up like gum and sticks to the sides of the bottle and wont spray out of the brush. Is this just the thinner thats causing this mess or is it a bad batch of paint? :-)
Are you using the enamel or acrylic laquer paints? It sounds like you are using the later. Check the label. If it is the acrylic laquer, enamel thinner sometimes works. Too often it reacts the way you are describing. The right thinner to use with acrylic laquer is urethane thinner. It's available at most auto paint stores. If you don't have one near you, you can also order from coast airbrush who sells it in smaller amounts. [Reply]
I tried using this paint a LONG time ago. I was only ever able to use the pearl white over white base with boyd high gloss clear. I contacted Valspar (the makers of this paint) and they were very helpful and very informative. I would suggest you do the same and tell them the issues you are having. I do know that if you use the thinner that is provided under the Kustom Kolor label you will not have any problems with thinning the paint.
Incedentally,from what I recall, the rattle can version of this paint is enamel, where as the airbrush bottles are more of an acrylic urethane. But I would contact them to verify this information.
also, do a search and find the thread I started. there is a lot of information in it that may help you. [Reply]
There's good reason this "Kustom Kolor" stuff isn't available any more!
First of all, it is NOT real HOK paint. That was just a marketing ploy by Valspar...the colors are nowhere near as vivid. Kustom Kolor is only "by the makers of HOK"...it is most certainly not real HOK.
Secondly, they used formulas that were different from bottles to spray cans and from other hobby paints. Lots of incompatibility issues. Lots of people get a good base coat, lay down clear, and have it all crack.
From what I saw when it was new, it was junk. I still believe that. From the colors to the formula, to the fact that it was dropped so quickly...but people still think it's "real" HOK...and honestly, this junk gave the real HOK paint a really bad rap. I would never be able to trust it on a model, unless you do a spoon test or similar...for all levels, from primer to color to clear.
You can order hobby size jars of real HOK paint. You can also get it from Black Gold. Nice, vivid colors....none of the nonsense. [Reply]
If I use the paint from there should I get it in pre-reduced 1:1 or just get it straight? I've had automotive paint eat into the plastic before and dont feel like doing that again.:-) [Reply]
youll need automotive grade primer for that stuff or primer your cars with tamiya. depends i buy mine straight i like my mix a certain way. [Reply]
I've used Kustom Kolor with some success. Compatibility is the key. As Zoom Zoom said there are some substantial compatibility issues. Kustom Kolors makes a product called a "Reducer" and product called a "Thinner" for the Kustom Kolor line. The Thinner drys slower than the Reducer and makes the paint behave sort of like an enamel in terms of gloss and drying time, although it still drys much faster than an enamel. The "Reducer" makes it behave more like a lacquer. It can also be thinned with lacquer thinner. Kustom Kolors Acrylic Clear does not work well over their paint and will definitely cause it to crack. I use Crystal Clear, an acrylic, over either thinned or reduced Kustom Kolors paint and I've had no bad reactions. My paint samples are over a year old. Here is a picture of a custom mix of Kustom Kolors over duplicolor silver. The body was cleared after I took this picture.
I used testors lacquer "wet look" clear over Kustom Kolor and it came out great. I just did a little wet sanding and polished with Scratch X and waxed, you can see your face in it.
I really wish they would have labeled them as lacquer, acrylic, enamel, etc. That may be the entire issue to begin with. ...and smelling paint isn't really a good way to tell what its chemical properties are. [Reply]
