AF Mobile
Page 1 of 2
1 2 >
Car Modeling>Smoothing a puttied surface
675datsun 03:20 PM 10-23-2004
I've been practicing with Squadron white putty and whenever I use it, it dries to a porous surface. Sanding only reveals more fine holes!
I've heard of "Mr. Surfacer", is this the product people are using to fill in putty surfaces? How is it applied? What exactly is it?
Specifically, I am trying to fill in a door panel line/and a door handle with putty. It never looks smooth when the putty dries and I've done some heavy sanding.
Any help would be appreciated!
[Reply]
Jay! 03:30 PM 10-23-2004
Mr. Surfacer is like a thin, but gritty primer. The number tells the grit (500 or 1000). It works okay for what you're talking about; just smoothing the top surface.
[Reply]
Asmenoth 03:32 PM 10-23-2004
Mr Surfacer is putty disolved in thinner. 500 is the thickest and 1000 is the thinnest. You can probably use the 500 to fill the door panel line, it would just take some time. If you get this stuff, also get Gunze Sangyo's thinner to clean your brushes...Tamiya's might work as well...don't know. You can also get it in a spray can to use as primer, fills fine scratchs and leaves a nice smooth surface. When I use the white squadron stuff, I stire it around a bit first, apply and sand. Don't always get the little holes thing, but sometimes. I just reapply it and try again. You could also order Magic Sculp. Good stuff. Two part epoxy like Milliput and seems to smooth a bit easier than Milliput...even though you can smooth both with water, I've had an easier time with the Magic Sculp. It can be ordered anywhere from little 4oz containers all the way up to very large tubs. You can supposedly get it in stores, though I havn't seen it there. But you can order it at www.magicsculp.com .
[Reply]
appleseed 03:33 PM 10-23-2004
Use Tamiya Gray Putty thinned down with some Gunze lacquer thinner would produce an adequate substitute for filling in the pinholes if you can't get Mr. Surfacer.
a
[Reply]
675datsun 03:41 PM 10-23-2004
Perfect, thanks for the quick replies!
I'm going to track down this Mr. Surfacer character!
I'll post some pics after using it.
Thanks again!
[Reply]
ZoomZoomMX-5 04:19 PM 10-23-2004
After this project, throw away your Squadron putty. It's for amateurs. Magic Sculpt is great stuff! Evercoat Eurosoft automotive putty is also great. Superglue kicked w/ Bob Smith Industry's kicker (the only safe brand) is also a great filler. Squadron is slow drying and rough, some of the worst stuff made...there are far better choices. Tamiya putties are good too.
[Reply]
pre98zetec 04:37 PM 10-23-2004
Superglue mixed with babypowder is the hardest/best filler I've found, Drys as hard as a rock in less then 5 minutes but is a PITA to sand.
[Reply]
675datsun 05:43 PM 10-23-2004
Thanks for the advice! I wasn't aware of other putties, maybe I glanced over them at the hobby shop.
[Reply]
ItalianStallion131 06:06 PM 10-23-2004
well I just recieved 2 jars of Premier Utility Paste from Premier Hobby products. It was in my mailbox and I didnt order it which is the freaky part
[Reply]
ImolaEK 07:46 PM 10-23-2004
a
Does it have to be with Gunze Lacquer thinner? :-)Can i thin it with Tamiya Acrylic thinner? Because the shop that used to sell Gunze Sangyo products stopped selling their products just when i got my airbrush, what a b*tch :-) I also had those problems with epoxy putty but my epoxy putty had swirls in it. :-) At this stage the car is unfixable but im just asking for the future.
[Reply]
StephenDeli 09:42 PM 10-23-2004
I would doubt the acrylic thinner would work as it is water based and the putty is oil based. Basically it would be beating a dead horse.
[Reply]
Murray Kish 12:23 AM 10-24-2004
You can thin Mr. Surfacer with just about any generic lacquer thinner. But if you're going to spray it on, do it in mist coats. If you put it on too wet, the lacquer thinnner will attack the plastic.
Murray
[Reply]
StephenDeli 09:30 AM 10-24-2004
I was just browsing the tamiya website and they have primer in a bottle and laquer thinner???? I have never seen the stuff. I even browsed a whole bunch of online stores and cannot find it. I guess it must be new. But hey, primer for your airbrush!
[Reply]
ImolaEK 12:18 PM 10-24-2004
Yea the primer is new.
http://www.hlj.com/scripts/hljpage.cgi?TAM87075
Haven'theard about the lacquer thinner until now:-)
[Reply]
SHIFT_drift 07:39 PM 10-25-2004
yeah ive been using tamiya basic type putty and i get those pin holes too... i guess i should try to fins ome of that mr surfacer as well
[Reply]
Page 1 of 2
1 2 >
Up
