its me again im wondering how hard it would be to switch an 88 s-10's 2.5 engine to a 2.8 v6 or maybe a 4.3 if possible if you can tell me how hard it is and how much it might cost it would be extremely helpful thanks ahead of time [Reply]
The 2.8L is one of Chevy's worst motors ever, and I'll never use one in another truck or re-build one again.
I'm told that the 2.5L is lousy too.
Try getting a complete running 4.3L truck around the same year that's been rear ended hard (trucks involved in front end collisions might have internal engine damage)
Then take 1 part out of yours at a time, then that part from the donar truck and transfer it over, 1 piece at a time.
Good Luck, it's a lot of work, but worth it if you have the time and patience [Reply]
There is a very small chance that I'm wrong, but I would have to say No.
The 2.8L is from the 60degree motor family and they have their own bell housing.
These same transmissions will also fit the 3.1L and the 3.4L engines (both much better motor choices used in Comaro's)
If you really want to use a 2.8L for some reason then I would really sugest that you use the transmission from a 2.8L truck
Then use the 3.1L or 3.4L motor from a comaro
Just say that I have 2 good running 2.8L motors, 1 even recently rebuilt one in my present Blazer and I wouldn't sell them since I just don't trust those motors at all. The bearings just don't last long in them.
Like I said there is a very small chance that the transmissions are the same bell housing. But there is no way that a 2.5L is a 60 degree motor.
60 degree means that the cylinder banks are lined up 60 degrees apart.
The 4.3L has them lined up 90 degrees apart so it can be called a 90 degree motor
And since the 2.5L is an inline engine the 1 bank is lined right up
If you get a parts truck for the swap make sure that it has a good transmission in it, then your set either way.
If it's a standard transmission Advance Adaptors makes a bell housing for a v-6 or V-8 swap, although they don't recomend it due to the transmissions being weak. http://www.advanceadapters.com/catalog/037.html [Reply]
The 2.5 Is Far From Lousy. I Have Had 2 Of Them, And They Are Very Tough. Power Is Not Excessive, So, They Are Very Good In The Snow With Just A Little Extra Weight In The Bed. I Put 260 Lbs. Between The Rear Whels, And Wala ! Quite Economical Also. Easier To Work On Than The 4.3,a Lot Less Trouble. [Reply]
Don't even consider a 2.8L.... 4.3L would be the better way to go. Easiest swap would be to get an engine/tranny combo that way there'd be no worries about compatability...... Or maybe just go bonkers and slip a late model 5.0L (305 cu/in) V8 in the engine bay....lotta info on the swap. The 4.3 is simply 3/4 of a 350 so why not add the missing two cylinders as part of the swap?
Have you looked up any of the GM 2.5L/Iron Duke/Tech 4 info on the web? This engine will never be a hotrod but you can work some magic with it...... believe it or not you can buy some performance parts for this engine...... just a thought.
He could drop in a 454. That would really make it something that you don't see every day.
Mate that to a Turbo 400 with a Gear Vendors over / under drive unit (basicly making a six speed auto) and he could out-pull a Viper [Reply]
