AF Mobile
Page 1 of 2
1 2 >
Let's get Technical!>turbo b20?
spawnliban 12:27 PM 12-04-2006
Is it good idea to turbo b20? or do i gotta do alot of modifications?
[Reply]
CivicSpoon 01:26 PM 12-04-2006
If you want it to last, then you'll need to do sleeves, pistons, and connecting rods.
[Reply]
spawnliban 03:03 PM 12-04-2006
ok now one more thing not too sure if you can answer this but here it goes
potential wise b20vtec or b20turbo ?
price wise b20vtec or b20turbo ?
i have a feeling its both b20vtec lol.
[Reply]
Schister66 04:12 PM 12-04-2006
not necessarily true....it depends entirely on the power goal and the setup
[Reply]
spawnliban 05:11 PM 12-04-2006
at least 300whp i might be dreaming but wanna see if its possible
[Reply]
CivicSpoon 08:36 PM 12-04-2006
True, but most people want enough power to need a good rebuild. Or they end up turboing it with a little boost and in the end turn it up anyways.
Yes spawnliban, the B20/vtec is the answer to both those question. Potentially, you could build the b20/vtec and then turbo it. And Building up the b20/vtec will be less expensive as buying a turbo kit (though you can piece together one for a lot cheaper than buying a prefabbed kit). Really depends on how far you're willing to go with it.
[Reply]
spawnliban 12:35 AM 12-05-2006
well before i started this project price wasnt a thing till i realized how much i paid for everything lol. anyway i'll prolly go with turbo first then vtec and see how that works out. i'll prolly do the suspension before i get to the turbo
[Reply]
Schister66 02:14 AM 12-05-2006
On my stock engine 99 GSR, i did my setup like this....
1. Standard setup....no frills. Made a respectable 275whp on a Dyno Dynamics dyno
2. Replaced turbo, topmount manifold rather than the log, a 3" downpipe and exhaust, Crome Pro/Hondata S2b, RC880s rather than 550s
3. Engine rebuild....Eagle/CP----no sleeves
what i'm getting at, is that if you dont have the money to do it all at once, then just go in stages, but make sure they're logical stages. Personally i would ditch the B20 and find an LS engine because the stock sleeves are stronger
[Reply]
spawnliban 04:21 PM 12-05-2006
Err i cant ditch the dam b20 not just yet. thats the hardest part i try to do alot of research but the thing i might never get is what to do. So far this is what ive done b20b s1 exedy clutch/finanza flywheel/2.25 custom cat back wit 2.5' muffler now the vtec has to all go in at one time. even if i do vtec tommorow wit the SI head, its only gonna be like 160 whp which sucks! dont know which pistons to go with if i should touch the cam gears change manifold all that good stuff. clueeeless :-)
[Reply]
Schister66 06:46 PM 12-05-2006
toss a GSR head on it and you're done w/ the VTEC part of it. The stock manifold will work just fine, but if you want to upgrade eventually, then do it. You could make 250whp easily on the stock engine AS LONG AS you have a solid setup and you have the car professionally tuned.
[Reply]
spawnliban 11:50 AM 12-06-2006
I will definately get the car tuned by this place i know gonna cost me I think havent checked prices and all, but, with setup do you mean changing the internals like pistons and all?
[Reply]
Schister66 01:10 PM 12-06-2006
no, you'd be fine on a stock internal setup at that power level...
[Reply]
spawnliban 02:32 PM 12-06-2006
so basically your telling me ima get 250whp IF i add gsr head on my car. obviously after i get the following :
1. New rod and main bearings.
2. New head gasket, Oil pan gasket, rear main seal, Oil return gasket, oil filter
3. Thrust washers
4. fittings for running the external oil line.
5. New VTEC Water pump.
6. New VTEC oil pump.
7. New VTEC Timing belt.
8. ARP Bolts
- Intake, Headers, and exhaust
* thanks to Tom...a.k.a. (simple4012) and mark (NAspirated). for that :-)
[Reply]
Schister66 04:47 PM 12-06-2006
to make that power level you need to put a turbo setup on your STOCK B20 (unless there's something wrong with it) and get it tuned professionally....you do not need to rip it apart and rebuild it IF it is in good condition
[Reply]
spawnliban 10:17 PM 12-06-2006
well vtec and turbo 250whp makes sense, now would you ever sell ur turbo? :-)
[Reply]
Page 1 of 2
1 2 >
Up
