AF Mobile
Page 1 of 2
1 2 >
'88 - '91 Civic | CRX | Wagon | Shuttlee>Fiberglass or Urethane
Carnivore 07:34 PM 03-11-2003
i was jus wondering when i get my kit what should i look for, quailty wise?.........what do you think is better?,........high grade fiberglass kit or the more expensive urethane ones?..........what about hoods too, carbon or fiberglass:smoker2:
[Reply]
Cjz89civic 08:38 PM 03-11-2003
more expensive urethane ones. Just look at cars that have been into wrecks with fiberglass there is fiberglass eveywhere. Urethane usually bends and is not broken. Also is the car is lowered fiberglass with crack if you scrape a curb to many times.
[Reply]
Tony 08:46 PM 03-11-2003
Urethane is what your factory bumpers are made out of. So you can just guess that they are better quality
[Reply]
jeef 09:25 PM 03-11-2003
Originally Posted by :
yeah what he said my fiberglass bumper is a pain in the arse... nice thing about them is they can be repaired....it it doesn't take too much to damage them
[Reply]
Tony 10:01 PM 03-11-2003
You can repair urethane also, if you know how
[Reply]
XxLuckyLisaxX 11:07 PM 03-11-2003
i've seen so many cracked fiberglass kits, you go see a car your interested in buying and the idiot has a cracked kit, looks like total shit
[Reply]
johnnym 10:02 PM 03-13-2003
Each type has pros and cons...
Fiberglass I find seems to fit better while the urethane tends to be harder to work with. Urethane will take minor accidents really well but the paint seems to crack on them much easier since they are much more flexable. Fiberglass does crack if you do get into accidents or tend to curb it once in awhile... Oh well good luck deciding...
[Reply]
Tony 10:06 PM 03-13-2003
Like I said earlier, stock bumpers are usually made out of Fiberglass, therefore, if painted correctly, the paint won't chip, but if the paint job was rushed on them, the paint looses its flexibility and chips easer, and also depends what primers, basecoats, and clear coats you use, some are made for flexible parts, while others are not. Just a little more info there for you.
As for fitment, i don't know for sure, i do know the paint though.
[Reply]
seth 90DX/ZC 10:27 PM 03-13-2003
Originally posted by Tony
Like I said earlier, stock bumpers are usually made out of FIBERGLASS,
Uhh.. you meen urethane I think... I have a urethane WW bumper and the thing is droping paint everywere! If I spray it too hard with a hose it flakes off... So Im leaning more towards a fiberglass kit... However the urethane's arent too much more... I dunno, it needs to be powdercoated or something... Can you powder coat non metalic objects? Also do they make the FEELS kits in uretheane?
[Reply]
GTA 11:36 PM 03-13-2003
no where i have seen.
[Reply]
IM4U2NV81 08:58 AM 03-14-2003
anyone know how? I could sure use this info. My WW front end is broken in 2 places from the curb that ran into me :silly2:
[Reply]
Tony 11:12 AM 03-14-2003
yea, thats what i meant to say seth. Like i said though, if you paint it right, it won't flake off, much like if you do anything right, it shouldn't mess up, its just a matter of doing it right.
uhhhh.....i don't know exactly how, but i do know that you can repair it. Try going to some parts store and asking them. If i wasn't out for spring break i would ask my instructor more about it, but needless to say, im out for spring break and can't ask him.
[Reply]
MyFirst4G 09:02 PM 03-15-2003
If this happens, whoever painted ur kit did not use FLEX PRIMER and did not use FLEX PAINT, cause Urethane is made to FLEX and if the paint does not flex, it will just crack!
[Reply]
Tony 09:12 PM 03-15-2003
HEY!!!!!!!!!!!!!!! Isn't that what I have said twice already? I think I have. No offense there Ali.
If you use primer, basecoat, and clearcoat that is made to flex, it won't chip that easy. Some paints(primers, basecoats, and clearcoats) are made to flex, others are not, then there are some that aren't really made for it to start off, but you are able to add some type of flex additive to make it flexible. Also, the flash time for each coat is critical. If you try and rush it, you loose flexibility, if you let it take its time like its supposed to, it will be flexible. So when painting flexible parts(i.e. bumpers, side skirts, etc.) take your time and do things right. Otherwise it will chip. And if you take it to someone else to paint it, make sure they do it right.
Thank you, come again :-):-)
[Reply]
MyFirst4G 09:15 PM 03-15-2003
Man, i should stop jumping down to the bottom...... i should read instrad of skim.... :-) i'm such a lazy bastard. or maybe i'm just :bonghitte
[Reply]
Page 1 of 2
1 2 >
Up
