AF Mobile
Page 4 of 6
< 1 2 3 4 5 6 >
Camaro Discussions>tips for a 400
PWMAN 09:43 PM 08-09-2003
Originally Posted by :
Originally posted by TorinoGT69
One thing to remember with pontiacs is that its the low end torque not the hp that makes them fast.
Exactly, that is why you need a dual plane manifold and mild gears. No more than 3.55, and radical cams only steal low end power.
[Reply]
TorinoGT69 09:52 PM 08-09-2003
I did not argue with you about the dual plane manifold. The performer rpm is a great manifold thats what I would recommend but at the time the car was built I was describing that manifold did not exist and the performer was exactly like a stock intake. Look at the ram air IV cam pontiacs react well to long duration. if you run a cam with a short duration you just increase the already abundant low end torque of the engine and do nothing to help the mid range power. Then you end up with a car that will not hook up and when it does it is already past its powerband.
[Reply]
petereggy 03:59 AM 08-10-2003
yah so I will run the same came as your friend exept I will use a preformer RPM cam
which should only increase torque
[Reply]
PWMAN 01:22 PM 08-10-2003
You mean performer INTAKE right? edelbrock cams suck, thats the only thing i've ever seen that they suck at. Otherwise, edelbrock is good.
[Reply]
TorinoGT69 01:31 PM 08-10-2003
yeah intake not cam I was typing fast.
[Reply]
petereggy 08:00 PM 08-10-2003
o crap I ment the intake too their cams do suck
edelbrocks carbs arent the greatest either and their headers kinda suck as well other then that they are a good company
[Reply]
petereggy 08:02 PM 08-10-2003
which do you think is better a preformer RPM air gap intake or just the regular preformer RPM
is it worth the price difference?
[Reply]
PWMAN 09:04 PM 08-10-2003
I don't think they make the air-gap for pontiacs do they?
If they do then get it, providing that it can fit underneath your hood! I don't think it will, I've seen one on a small block chevy and it was very tall. It probably won't work on a car.
[Reply]
petereggy 10:15 PM 08-10-2003
well I am planning on putting a 4 inch cowl or so on my car so im guessing that the air gap will fit underneath the hood even with a tall air cleaner
[Reply]
TorinoGT69 12:53 AM 08-11-2003
I don't think there is an air gap for pontiac. there would be no point pontiacs have a seperate valley pan so there is already a gap under the intake.
[Reply]
petereggy 12:56 AM 08-11-2003
yah I have looked and I havent found an air gap manifold for pontiac but o well im sure the preformer RPM will do just fine
[Reply]
TorinoGT69 12:57 AM 08-11-2003
it should fit no problem if you have a 4inch cowl .
[Reply]
petereggy 12:58 AM 08-11-2003
yah I think I will have lots of clearance under a 4 inch cowl but I will still wanna try and fit everything underneath the stock hood because the cowl will be one of the last things I buy
[Reply]
TorinoGT69 12:59 AM 08-11-2003
do you have a shaker hood or flat or formula type?
[Reply]
petereggy 01:00 AM 08-11-2003
with a built up 400 do you think I will need to run an after market distrubuter?
or could i get away with running a msd ingnition pack whch has a coil, the 6A box and a couple other things
[Reply]
Page 4 of 6
< 1 2 3 4 5 6 >
Up
